[GRASSLIST:9483] Re: SRTM shifted 0.5 the res in X and Y axis from the r.mapcalc output
Markus Neteler
neteler at itc.it
Wed Dec 14 14:49:52 EST 2005
Maciek,
since we have spent significant time on GDAL vs SRTM
vs BIL sv GRASS cell positioning, I wonder that
SRTM in GRASS is shifted. It's at least unlikely.
See the r.in.srtm script for comments.
Probably you are facing a nearest-neighbor problem?
I don't trust d.zoom to much...
Markus
On Wed, Dec 14, 2005 at 08:28:51PM +0100, Maciek Sieczka wrote:
> This might be connected with my [GRASSLIST:9409].
> SRTM tiles imported with r.in.srtm are shifted 0.5 the resolution in X
> and Y axis from the native Grass rasters cretaed with r.mapcalc in the
> same location.
> See the attached picture and notes below. I'm not doing anything
> unusuall. Why are these two rasters shifted? I don't think they should
> be. I guess that when importing data like SRTM (BIL), where the
> coordinates are of the cell centre, into Grass, where coordinates are of
> the cell ll corner, shuch data should shifted to conform to Grass grid.
> Correct me please if this is rubbish what I suppose, but I'm puzzled
> that I have two rasters of the same res in Grass and they don't fit each
> other.
> # 1. import a 3" SRTM tile
> r.in.srtm input=/home/maciek/gis/dane/srtm2/N49E023.hgt.zip
> output=N49E023
> g.region rast=N49E023 -p projection: 3 (Latitude-Longitude)
> zone: 0
> datum: wgs84
> ellipsoid: wgs84
> north: 50:00:01.5N
> south: 48:59:58.5N
> west: 22:59:58.5E
> east: 24:00:01.5E
> nsres: 0:00:03
> ewres: 0:00:03
> rows: 1201
> cols: 1201
> # colour it and zoom to the top-right corner of the tile to see single
> # cells
> r.colors N49E023 col=grey.eq
> d.rast N49E023
> d.zoom
> # create a GRASS raster there, in the same resolution
> r.mapcalc 'test=rand(0,1000)'
> # increase the resolution so that any small shift is visible
> g.region res=0:0:0.1 -p
> zone: 0
> datum: wgs84
> ellipsoid: wgs84
> north: 50:00:09N
> south: 49:59:48N
> west: 23:59:54E
> east: 24:00:12E
> nsres: 0:00:00.1
> ewres: 0:00:00.1
> rows: 210
> cols: 180
> # display the Grass raster and overlay an SRTM
> d.erase; d.rast test; d.rast N49E023 -o
> # here's the shift
> See the attachment - grey is the SRTM, r.mapcalc ouput in random colors.
> Maciek
> ,,Kuchnia polska PWE" - Idealny prezent pod choink?!
> Najs?ynniejsza ksi??ka kucharska, kt?ra pomo?e na nowo odkry? przysmaki polskiej kuchni
> Z okazji ?wi?t 10% zni?ki na stronie http://www.pwe.com.pl/51552.xml
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
