[GRASSLIST:9485] Re: SRTM shifted 0.5 the res in X and Y axis from the r.mapcalc output
William Kyngesburye woklist at kyngchaos.com
Wed Dec 14 16:12:38 EST 2005
Ack, I was partially right about the zoom thing.  d.zoom restrains
itself to the region resolution, but it's aligning to a whole degree,
not the 1.5 sec offset that it started at.  Thus it appears to be
half a cell off.
On Dec 14, 2005, at 2:50 PM, William Kyngesburye wrote:
> I don't think there is a problem.  I worried about and checked this
> when I started converting and filling SRTM data.
> Since the cell centers of a SRTM tile range from degree to the next
> degree (so there is a 1 cell overlap between all tiles), the GRASS
> region will appear to be off by 1.5 seconds - it won't line up on
> even degrees.
> The problem, in your example at least may be that you used d.zoom
> before r.mapcalc.  d.zoom doesn't restrain itself to cell
> boundaries (as you can see from the region after zooming), and
> r.mapcalc will create the test raster at whatever region is set.
> Then, of course they will not align.
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
