[GRASSLIST:9500] Re: script for creating map
    orkun
    temiz at deprem.gov.tr
    Thu Dec 15 05:57:46 EST 2005
Maik Trömel wrote:
> Hello Grass-Users,
> I want to write a script that creates a map as a png-file. I know how
> to make it by hand. But when I try to script it, it doesn't work
> because I can't open a monitor. Is there a possibility to create a map
> with a script.
> If "yes". How can I do this.
> Thanks for you help.
> Greetings
> Maik
thank you
v.info -c jgenel1
Displaying column type for database connection of layer 1:
INTEGER|cat
CHARACTER|yas
INTEGER|count
DOUBLE PRECISION|sum_cat
in postgresql
bzk=# \d jgenel1
         Table "public.jgenel1"
Column  |         Type          | Modifiers
cat     | integer               |
yas     | character varying(80) |
count   | integer               |
sum_cat | double precision      |
______________________________________
XamimeLT - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster at deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
