[GRASSLIST:9510] Re: switching to postgres
Kirk Wythers
kwythers at umn.edu
Thu Dec 15 11:49:39 EST 2005
On Dec 15, 2005, at 2:34 AM, Radim Blazek wrote:
> Each new vector will store attributes in database previously set by
> db.connect. If you have a vector with attributes in dbf files,
> you set your db to postgres (db.connect driver=pg datbase=...)
> and then copy the old vector with g.copy the new one will use
> postgres for attributes.
Here are the results of the above procedure using the spearfish data
(I'm attempting to narrow down the possible sources of error):
1. I created a database named spearfish_soils in postgres
truffula:/usr/local/pgsql/bin kwythers$ psql -l
List of databases
Name | Owner | Encoding
postgres | postgres | SQL_ASCII
spearfish_soils | kwythers | SQL_ASCII
template0 | postgres | SQL_ASCII
template1 | postgres | SQL_ASCII
timber | kwythers | SQL_ASCII
ts2325 | kwythers | SQL_ASCII
(6 rows)
2. I set the db connection to postgres with db.connect, then checked
to make sure it was set properly
GRASS 6.1.cvs (spearfish60):~ > db.connect -p
driver:pg
database:host=localhost,dbname=spearfish_soils
schema:(null)
group:(null)
3. I used g.copy to copy soils from PERMANENT to spearfish_soils in
the current mapset
GRASS 6.1.cvs (spearfish60):~ > g.copy vect=soils,spearfish_soils
COPY [soils at PERMANENT] to current mapset as [spearfish_soils]
>> GRASS 6.1.cvs (arrowhead_utm):~ > db.copy from_driver=dbf
>> from_database=./ from_table=townships to_driver=pg
>> to_database="host=localhost,dbname=ts2325" to_table=townships
>> and got the error:
>> DBMI-DBF driver error:
>> Table 'townships' doesn't exist.
>> Error in db_open_select_cursor()
> That could be a bug in case you have townships.shp in your current
> directory.
4. Check to see that the vector file 'spearfish_soils' exists... it does
GRASS 6.1.cvs (spearfish60):~ > g.list vect
vector files available in mapset user1:
spearfish_soils
vector files available in mapset PERMANENT:
archsites soils t_9961_300 t_9961_500_bks
t_roads_second
bugsites streams t_9961_300_all t_county t_tracts
fields t_9961_100 t_9961_300_bks t_hydro tractids
quads t_9961_100_all t_9961_400 t_powerlines tracts
railroads t_9961_100_bks t_9961_400_all t_rails
transport_misc
roads t_9961_200 t_9961_400_bks t_roads
trn_sites
rstrct_areas t_9961_200_all t_9961_500 t_roads_inf
twp_range
sections t_9961_200_bks t_9961_500_all t_roads_prime
5. Check to see that the data was copied from dbf 'soils' to pg
'spearfish_soils'
spearfish_soils=# SELECT * FROM spearfish_soils;
cat | label
1 | Aab
2 | Ba
3 | Bb
4 | BcB
5 | BcC
6 | BeE
7 | Bhe
8 | Bkd
9 | CBE
10 | CaD
11 | CaE
12 | Cc
13 | GBE
14 | GaD
15 | GcD
16 | GdE
17 | GeD
18 | HBF
19 | Ha
20 | KaB
21 | LaE
22 | MaC
23 | MaD
24 | McD
25 | NaB
26 | NaC
27 | Nac
28 | NbD
29 | NcD
30 | NdB
31 | NdC
32 | PbE
33 | PcB
34 | PcD
35 | Pe
36 | RBF
37 | RCF
38 | RaE
39 | SaA
40 | SaB
41 | SbB
42 | Sd
43 | ShA
44 | Sk
45 | TaA
46 | TaB
47 | TaC
48 | VBF
49 | VCE
50 | VaA
51 | VaB
52 | VaC
53 | WaA
54 | Wb
(54 rows)
spearfish_soils=#
So far so good. This is looking great!
6. use db.describe to check out the vector in GRASS
GRASS 6.1.cvs (spearfish60):~ > db.describe table=spearfish_soils
driver=pg database=spearfish_soils
DBMI-Postgres driver error:
select * from spearfish_soils where oid < 0
ERROR: column "oid" does not exist
What is oid? I can see from the columns that postgres printed out
that I have only columns cat and label, no oid. Is this something
that should have copied and did not?
Thanks,
Kirk
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20051215/cfbd4e5c/attachment.html
