[GRASSLIST:9512] Re: switching to postgres
    Kirk R. Wythers
    kwythers at umn.edu
    Thu Dec 15 13:07:30 EST 2005
On Dec 15, 2005, at 11:54 AM, Radim Blazek wrote:
> This is bug.  By default postgres is using OID (hidden) column
> for each table. But it is possible to configure postgres to create
> tables
> without that column. My fault, it was stupid to use oid.
> Fixed in CVS.
I'll cvs up and recompile. Thanks Radim. I like your g.copy solution
a lot. It makes moving vectors from dbf to pg very straight forward.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20051215/d3db2116/attachment.html
