[GRASSLIST:9514] Re: aaargh! another location lost
Ian MacMillan
Ian.MacMillan at pomona.edu
Thu Dec 15 17:29:35 EST 2005
Lorenzo and others, I have tried to re-create this scenario several
times, but can't repeat it (only the two times I have written about).
I can't tell you if it would happen without using the aqua interface,
but each time it did happen while I was using that interface (I am not
sure if it could have anything to do with it or not).
The file names of the locations were rather simple:
worldmerc
latlong_wgs84
the mapset names were just:
ianmacmillan
I tried to find these locations on my system, but they haven't been
moved. I have looked for individual files within the mapsets, and
can't find those either.
I am currently running a virus scan on my computer, but I doubt that is
it as the only data loss I have ever experienced are these two
locations, and they were both the target locations of the imagery
groups that I was working on while the loss happened.
Thanks all for your thoughts (keep em coming), I will keep trying to
figure things out on my end as well.
-Ian
On Dec 15, 2005, at 8:51 AM, Lorenzo Moretti wrote:
> Hi Ian
>> Hi all, so I hate to write about this again, but somehow I have had
>> another location erased while using imagery commands. This is the
>> second time this has happened to me. I have a hard time narrowing
>> down how it happened this time, but last time I was using i.points,
>> and a location disappeared (~300 MB of data) (GRASSLIST 8827). This
>> time I couldn't pin down which imagery command did it (I can only pin
>> it down to a 5 minute time frame), but I again encountered problems
>> using i.points. I tried to run the program, but got a 'false start'
>> where after entering the imagery group in the pop-up terminal window,
>> the terminal window disappeared, and i.points never started up.
>> Within minutes after this, I noticed that the target location had
>> been erased (another ~500 MB down the drain). Again, checking my
>> bash_history, there is nothing there that would indicate a command
>> that would do this. I have also checked my whole computer for this
>> location (or any files in it), to no avail.
>> I am running 6.1cvs (Dec-12 Lorenzo's binaries) on mac 10.3.9.
>> I can't understand what can be happening. I have tried repeating my
>> steps exactly, and can not get the same error in the program to
>> occur. I have no idea how to isolate the issue at all. I have had
>> no other troubles with this computer in 1.5 years of use, it has
>> plenty of memory, and runs really smooth (like most macs).
>> This is really strange behavior obviously, but very troublesome to me
>> since it has happened twice now, though with slightly different
>> causes.
>> I have no idea how to test for this behavior, and looking at the
>> responses from last time, I am not sure how they could necessarily
>> result in this behavior multiple times. Any other ideas out there?
>> -Ian
>> PS I know I need to back up data, and I do, but this is still
>> infuriating.
> This is a tragedy.
> For a test.
> Test under X11 only (menu and xterm) and under X11 and Aqua menu
> (menu).
> Duplicate another location and re-try the i.points.
> Try and send me the result.
> and you wrote
>> Has anyone found out why malloc errors are appearing using v.in.ascii
>> with Lorenzo's binaries? I can't import any ascii files using 6.1cvs
>> anymore, I have to revert back to 6.0. The exact same commands that
>> produce an error like:
>> *** malloc[9282]: Deallocation of a pointer not malloced: 0x501740;
>> This could be a double free(), or free() called with the middle of an
>> allocated block; Try setting environment variable MallocHelp to see
>> tools to help debug
>> tools to help debug
>> tools to help debug
>> *** malloc[9282]: error for object 0x501740: Incorrect checksum for
>> freed object - object was probably modified after being freed; break
>> at szone_error
>> Segmentation fault
>> work using 6.0. I have run into this problem intermittently since
>> early October, and have seen it mentioned a few other times on this
>> list since then.
>> Any ideas?
>> Thanks for your time,
>> Ian
> Send me your specific ascii file (tell me the coordinates) because I
> want to test with other libraries. I don't know if it is a library
> problem.
> Bye
> _______________________________________________________________________
> ___
> || Lorenzo Moretti e-mail: lorenzo.moretti at bologna.enea.it
> ||/|/| ENEA prot/idr Web: http://wwwamb.bologna.enea.it/
> || | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/
> (ris.)
> ~~~~~~ 40128 BOLOGNA - ITALY Ph: +39-0516098086 Fax: +39-0516098131
> ENEA - Ente Nazionale per le Nuove Tecnologie, l'Energia e l'Ambiente
> ENEA - The Italian Agency for New Technologies, Energy and the
> Environment
> ___
What happens if a big asteroid hits Earth? Judging from realistic
simulations involving a sledge hammer and a common laboratory frog, we
can assume it will be pretty bad.
- Dave Barry
This message has been scanned by Postini anti-virus software.
