[GRASSLIST:9536] Re: Replacement for r.volume
Michael Fecht michael.fecht at uibk.ac.at
Fri Dec 16 06:32:09 EST 2005
Hi Roy,
i had the same problem.
Here is my solution:
- checkout the region's resolution
- calculate the area of one cell (resx * resy)
- run r.stats for your surface (dem)
- multiply the area of a cell with the sum of the surface's values
Michael
Roy Sanderson wrote:
 > Hello
 > What is the replacement command for r.volume, which doesn't seem to exist
 > in GRASS 6.0 ?
 > Many thanks
 > Roy
 > Roy Sanderson
 > Institute for Research on Environment and Sustainability
 > Devonshire Building
 > University of Newcastle
 > Newcastle upon Tyne
 > NE1 7RU
 > United Kingdom
 > Tel: +44 191 246 4835
 > Fax: +44 191 246 4999
 > http://www.ncl.ac.uk/environment/
 > r.a.sanderson at newcastle.ac.uk
Michael Fecht
Freisingstraße 2
A6020 Innsbruck
+43 (0)650 8131923
