[GRASSLIST:9552] Re: script for creating map
    Michael Barton
    michael.barton at asu.edu
    Fri Dec 16 18:34:36 EST 2005
Check out the d.out.file script (or it's predecessor, d.out.png) that I
wrote and is included with GRASS. This will export whatever is on the
current monitor to a png (or other formats if you have gdal). Add d.mon and
d.rast and/or d.vect and you can script the creation of a map and its export
to png.
Michael
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Maik Trömel <maik.troemel at maitro.net>
> Date: Thu, 15 Dec 2005 11:28:48 +0100
> To: GRASSLIST <GRASSLIST at baylor.edu>
> Subject: [GRASSLIST:9498] script for creating map
> Hello Grass-Users,
> I want to write a script that creates a map as a png-file. I know how to
> make it by hand. But when I try to script it, it doesn't work because I
> can't open a monitor. Is there a possibility to create a map with a script.
> If "yes". How can I do this.
> Thanks for you help.
> Greetings
> Maik
