[GRASSLIST:9554] Re: rectifying images
    Manuel Seeger
    seeger at uni-trier.de
    Sat Dec 17 07:09:34 EST 2005
Hello all, hello Markus,
I would like to test the rectify module, too. I have a lot of scanned
air photographs from the pyrenees...
For this I would love to have some instructions - for dummies - how to
compile new modules into my system. I've started now, after some years
os wishing it, with GRASS 6.0.2 on a fast and heavy of memory machine
running with SuSe 10.0, tryed to compile "everything" and had some
problems... but it works fine....
thanks to all developpers for their good work!
Manuel
Markus Neteler schrieb:
>hi,
>a student of us has implemented improved versions of
>i.points and i.rectify based on previous work as published
>in our last year's Bangkok paper.
>The new version
>- use FFT correlation to automatically search for ground
>  control points in a user given window pair (so, just zoom
>  more or less the same zone in the master and the slave
>  image)
>- do this for the entire stripe of images
>- bad GCPs are identified and eliminated
>- run the modified i.rectify to rectify the entire stripe.
>We are using this to geocode historical images. I still
>have to cleanup the code to the current coding standards,
>then I need a beta tester :-)
>If course you can also work with just 2 overlapping images
>and enjoy the automated GCP search.
>Interested?
>Markus
>On Fri, Dec 16, 2005 at 03:13:03PM +0100, Wolfgang Zillig wrote:
>>I'm not sure if this helps for my problem (perhaps I was not clear
>>enough in my description). The problem is, that I have one original
>>images which I want to use as reference and all others are more or less
>>deformed but no one at the same level. So I think I will have mark my
>>reference points in all deformed images. When I understand right
>>grouping is good, when you have many images whith the same deformation,
>>or am I wrong?
>>Wolfgang
>>Hamish schrieb:
>>>>I need to rectify several images in the next time. Is there a way to
>>>>automatize this procedure a little bit? I have the "original" image and
>>>>then about 10 to 20 images which needs to be corrected that they refer
>>>>to the original one. I thought of something like saving the correction
>>>>points of the original image to an file, so that I don't need to mark
>>>>again (the reference points will be the same for all images) and I only
>>>>need to specify them in the images which needs to be rectified.
>>>Add all the images to a group, then rectify the lot.
>>>i.group input=name[,name,...]
>>>i.rectify -a
>>>Hamish
Dr. Manuel Seeger
Wiss. Assistent 			Scientific Assistant
Physische Geographie 			Dpt. of Physical Geography
FB VI - Geographie/Geowissenschaften 	Geography/Geosciences
Universität Trier			University of Trier
D - 54286 Trier
Tel.:	+49-651-201 4557
Fax:	+49-651-201 3976
Web:	http://www.uni-trier.de/uni/fb6/geographie/mitarbeiter/Seeger/
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20051217/05c17cb4/attachment.html
