[GRASSLIST:9594] Re: v.buffer: area boundary around line? Wanted: howto!
Tom Russo
russo at bogodyn.org
Wed Dec 21 10:42:55 EST 2005
On Wed, Dec 21, 2005 at 11:22:33AM +0100, we recorded a bogon-computron collision of the <Wolfgang.Qual at gmx.net> flavor, containing:
> Hi List,
> I tried to create a new area boundary around a line theme. Thought it would
> be easy to do it like this:
> v.buffer in=ausschnitt out=buff_ausschnitt bufcol=gesamtbr type=boundary
> But GRASS won't create a new theme. After that, I tried to first create a
> line buffer theme (works fine) and then convert it to a area boundary theme
> using v.type. However, the new area boundary theme does not have the shape
> of the line buffer theme.
> BTW, the line theme looks like this (street network):
> | | ...but I get s.th. XXXXXXXXXXXX
> | | like this: XXXXXXXXXXXX
> -------------- XXXXXXXXXXXX (area inside)
> I would greatly appreciate to receive some hints...
I'm not exactly sure why this is, but apparently d.vect displays these areas
by showing both categorized polygons (the ones you intended) and
uncategorized polygons (the ones that fill all the spaces in between). If you
try
d.vect map=buff_ausschnitt where="cat<>0"
I think you'll get only the areas you really wanted.
Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/~russo/
Tijeras, NM QRPL#1592 K2#398 SOC#236 AHTB#1
"The only thing you can do easily is be wrong, and that's hardly
worth the effort." -- Norton Juster
