[GRASSLIST:9614] Re: Using unixODBC to connect GRASS to MySQL [Mac] - please test iODBC anyone
Nick Cahill ndcahill at facstaff.wisc.edu
Thu Dec 22 16:14:16 EST 2005
OK, I just tried it again, this time running grass61 -gui and so
avoiding the WISH and gui problems.
I tried a bit more fussing with the setup. ODBC is a mystery to me,
and I'm probably messing it up. I tried installing the driver first
in my own Library/ODBC directory, then in the system wide /Library/
ODBC, and experimented with both system DSN and user DSN's. The user
DSN didn't work:
db.test test=test1
create table grass_test1 (i1 integer, d1 double precision, c1 varchar
(20))
DBMI-ODBC driver error: SQLConnect():
[iODBC][Driver Manager]Data source name not found and no default
driver specified. Driver could not be loaded (0)
... etc. etc....
Setting up ODBC as a system DSN gave different errors:
db.test test=test1
(20))
[DataDirect][ODBC SequeLink driver][SequeLink Client]TCP/IP error,
connection refused (2306)
EXECUTE: ******** ERROR ********
insert into grass_test1 values ( 1, 123.456, 'abcd' )
So at least it seems to be locating the driver, but the driver isn't
connecting to the database?  Here the instructions that come with
FMP7 aren't that helpful to me; I'm sure they'd be enough for someone
who knows ODBC. I used the ODBC Administrator that comes with Mac OSX
10.4.3, set up a System DSN with values Host=localhost, Port=2399,
ServerDataSource = database name, in this case just ODBCTest.
Filemaker is set up to share the database via ODBC, and is running.
Ideas?
Nick Cahill
On Dec 22, 2005, at 5:34 PM, William Kyngesburye wrote:
> (I bumping this back to the list, Nick)
> On Dec 22, 2005, at 1:28 AM, Nick Cahill wrote:
>> Dear William,
>> Sorry, it's been a very hectic couple weeks and I had to put off
>> testing GRASS and Filemaker.
> I hear you.
>> I just made a stab at it - installing the ODBC driver and such. I
>> have FMP 7 and the driver, and hope they're configured correctly.
>> However, when I run your GRASS, I get an error:
>> channel "console1" wasn't opened for writing
>>     while executing
>> "error $fh"
>>     (procedure "run_cmd" line 24)
>>     invoked from within
>> "run_cmd 2"
>>     invoked from within
>> ".dialog1.run invoke"
>>     ("uplevel" body line 1)
>>     invoked from within
>> "uplevel #0 [list $w invoke]"
>>     (procedure "tk::ButtonUp" line 23)
>>     invoked from within
>> "tk::ButtonUp .dialog1.run"
>>     (command bound to event)
>> so I can't run any GUI commands.
> Is that right when you run grass in GUI mode?  ie grass61 -gui.
> Oh, your tcl/wish settings might be looking at a different Tcl/Tk.
> Try setting this in your .bash_profile:
> export GRASS_TCLSH=/usr/local/grasslibsx/bin/tclsh8.4
> export GRASS_WISH=/usr/local/grasslibsx/bin/wish8.4
> (or use setenv in .cshrc for the tcsh)
>> So I tried it from the command line. I had set up a FMPro database
>> called ODBCTest, shared it from within FM, but I don't have the
>> ODBC Admin program that lets me test whether the connection is
>> actually set up - so there may be a problem there. .In any case I
>> got:
>> GRASS 6.1.cvs (sardis):/usr/local/bin > db.connect driver=odbc
>> database=ODBCTest
>> GRASS 6.1.cvs (sardis):/usr/local/bin > db.test test=test1
>> varchar(20))
> I think this is where the DSN comes in.  As it says, iODBC doesn't
> have a DSN defined for the database you specified.  The DSN ties a
> specific database name (what you use in db.connect) to an ODBC
> driver and source database.  The GRASS docs for the db commands
> don't say much on this (maybe somewhere there is more info), but
> the GDAL docs on ODBC connections helped me to understand this.
> How you setup the DSN (parameters and such) is still hazy, all I
> know is you use ODBC Administrator.
> Someone on the list might know more about ODBC.  I hope we can get
> this working ^_^
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> Earth: "Mostly harmless"
> - revised entry in the HitchHiker's Guide to the Galaxy
