[GRASSLIST:9666] Re: real color landsat images
Thu Dec 29 06:32:47 EST 2005
Markus Neteler wrote:
> > > I know how to combine the band (_10, _20, _30) to real color images
> > > with r.rgb. But then the resolution is limited to 30m. Is there a way
> > > to get them in higher resolution with the pan band (_80)? When I use
> > > i.fusion.brovey I get always false color pictures. Any idea?
> > One option to try is rgb.hsv.sh, replace V with the panchromatic map,
> > then hsv.rgb.sh.
> It is important to change to the _80 resolution before replace V
> with the panchromatic map.
> > Hmm; those scripts don't appear to be included in 6.1, but they are in
> > 5.3.
> Naive question: What about
>  i.his.rgb
>  i.rgb.his
I wasn't aware of those, but they should do the job.
