[GRASSLIST:9672] Re: compilation (again)
    Markus Neteler
    neteler at itc.it
    Fri Dec 30 04:03:55 EST 2005
Ciao Paolo,
[maybe better posted to the devel list]
On Thu, Dec 29, 2005 at 05:47:25PM +0100, Paolo Cavallini wrote:
> Hi all.
> Still problems compiling grass from 6.1cvs:
... "still"? I thought it worked for you recently...
> checking if 64bit Sparc VIS support is requested... no
> checking system version (for dynamic loading)... ./configure: line 13675:
> unexpected EOF while looking for matching `''
> ./configure: line 13805: syntax error: unexpected end of file
> make: *** [config.status] Error 2
> Any hint?
What does
 cvs up configure
say (conflict)?
Best
 Markus
> All the best.
> pc
> Paolo Cavallini
> email+jabber: cavallini at faunalia.it
> www.faunalia.it
> Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy   Tel: (+39)348-3801953
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
