[GRASSLIST:9683] Re: r.proj - painfully slow or bug? (Cygwin, latest 6.1 CVS)
Ian MacMillan Ian.MacMillan at pomona.edu
Fri Dec 30 11:59:43 EST 2005
Robert, you want to make sure that your region in the target location
is set to the same size as the raster coming in.  If your region is
bigger than the raster, then that blank space needs to get interpolated
as well.  The easy way to do this is to create a vector of the region
you want to project with v.in.region in the original location.  Project
that into your target location with v.proj (usually an ~instantaneous
projection) run from the target location.  Set your region in the
target location to that raster, g.region vect=projected_vector.  You
might need to change the resolution manually.  Then run r.proj.
Hopefully this helps,
-Ian
On Dec 30, 2005, at 8:19 AM, Robert Kuszinger wrote:
> Hello!
> Is it normal that r.proj is running for an hour on a 9M raster data
> (from UTM to EPSG:23700) with nearest neighbour?
> Grayscale DTM.
> I don't know if it is working at all or simply frozen or buggy?
> I'm running Grass61 in Cygwin on a 1.4 MHz Pentium M Dothan with 1GB
> RAM (IBM TP R51)
> Where to check for temporary files or how to get a progress
> information?
> It displays this (see between lines), processor is running at 100% and
> nothing else happens....
> GRASS 6.1.cvs (magyarorszag):/cygdrive/m/grass > r.proj input=dk_cut
> location=latlong resolution=100
> Input Projection Parameters: +proj=latlong +no_defs +a=6378137
> +rf=298.257223563 +towgs84=0.000,0.000,0.000
> Input Unit Factor: 1
> Output Projection Parameters: +proj=somerc +lat_0=47.14439372222222
> +lon_0=19.04857177777778 +x_0=650000 +y_0=200000 +no_defs +a=6378160
> +rf=298.247167427
> Output Unit Factor: 1
> thanks
> Robert
This message has been scanned by Postini anti-virus software.
