[GRASSLIST:5588] v.to.rast and null values
David Orme d.orme at imperial.ac.uk
Tue Feb 1 07:34:57 EST 2005
I have a point vector connected to a postgresql table. I want to create
a raster from the vector using values from one of the columns and so I
can use:
v.to.rast behr_grid column=total_richness output=total_richness
This works fine _except_ that the psql column contains both 0 and null
values and the null values come through into the raster as zeros. Is
there an easy way to get it to recognize nulls? I can always update the
table to set NULL to -9999 and then use r.null, but I wondered if it
was possible to preserve the nulls in the first place.
Cheers,
David
