[GRASSLIST:5613] Re: import IDRISI raster
Martin Wegmann
wegmann at biozentrum.uni-wuerzburg.de
Wed Feb 2 16:29:20 EST 2005
Hi Marta,
thanks for your advice, I will do it the way you proposed if I can't find a
way to import IDRISI files directly.
I hoped that I could do it directly using a GRASS command (writing a script
for all files) due to the large number of raster files.
cheers Martin
On Wednesday 02 February 2005 11:12, marta.benito at uam.es wrote:
> Hi,
> I have done first exporting it from idrisi as GRASS format with the option
> ASCII.
> And then importing into grass this file with r.in.ascii
> Hope this helps
> Marta
> > Hello,
> > I have IDRISI raster files (rst, rdc) and would like to import them into
> > GRASS. I already found a post from 1996 concerning
> > r.out.idrisi/r.in.idrisi.
> > If this command was once created I assume it has been merged into
> > r.in.gdal. However the gdal raster format page does not list the IDRISI
> > raster format.
> > Does anybody knows a work-around to import IDRISI raster formats into
> > GRASS?
> > thanks, Martin
> Mensaje enviado mediante una herramienta Webmail integrada en *El Rincon*:
> ------------->>>>>>>> https://rincon.uam.es <<<<<<<<--------------
