[GRASSLIST:5634] Re: Creating DTM from shapefiles
    Moritz Lennert
    mlennert at club.worldonline.be
    Fri Feb  4 04:48:20 EST 2005
On Fri, February 4, 2005 10:42, MÄris NartiÅ¡s said:
> TNX for quick respnse and explanation. I will work with Grass 5.4.0
> instead of 6.0.0 to prepeare DTMs.
> Actualy as for newcomer to Grass I found lots of undocumented gochas
> in Grass. Dosumentation not always fuly explains output of commands,
> influence of aviable flags etc. I spend lot of time just experimenting
> with different things to find out what they do. I hope on better
> documentation after some time.
The best would be to give us precise indications on where documentation was
insufficient for you...the ideal would be for you to then write these parts
But already letting us know what is missing helps identifying priorities.
Moritz
