[GRASSLIST:5639] v.in.ascii Grass6.0
    Jan Bartholdy
    mailing_list at jan-bartholdy.de
    Fri Feb  4 09:31:24 EST 2005
Dear All,
here ist he error log from the import with v.in.ascii What is wrong? The
line was created by tcltkgrass (d.m respectively)
v.in.ascii input=/home/Jan_Bartholdy/cities.dat output=cities format=point
fs=| 'columns='\''x double, y double, name string'\''' x=1 y=2 z=0 cat=0
Cannot create table: create table cities2 ( cat integer, 'x double, y
double, name string length: 15' )Cannot create table: create table cities2 (
cat integer, 'x double, y double, name string length: 15' )
DOS text format found, attempting import anyway
Maximum input row length: 42
Maximum number of columns: 3
Minimum number of columns: 3
column: 1  type: double
column: 2  type: double
column: 3  type: string  length: 15
DBMI-DBF driver error:
SQL parser error in statement:
create table cities2 ( cat integer, 'x double, y double, name string length:
15' )
Error in db_execute_immediate()
Here are the data (19 lines like these)
14.51666667|-22.98333333|Walvis Bay
15.16666667|-26.63333333|Lüderitz
16.5|-28.66666667|Alexander Bay
18.35|-32.31666667|Elands Bay
Thanks, Jan
____________
Virus checked by G DATA AntiVirusKit
