[GRASSLIST:5647] Re: AW: Re: v.in.ascii Grass6.0
Mark P. Line
mark at polymathix.com
Fri Feb 4 15:41:09 EST 2005
Jan Bartholdy said:
> v.in.ascii input=/home/Jan_Bartholdy/cities.dat output=cities
> format=point fs=| columns='x double, y double, name string' x=1 y=2 z=0
> cat=0
> has printed the error:
> WARNING: DOS text format found, attempting import anyway
> Maximum input row length: 42
> Maximum number of columns: 1
> ERROR: ycol > minimum last column number
I'm surprised you don't have to escape the pipe sign (fs=|) if you're
giving this command line to bash.
-- Mark
Mark P. Line
Polymathix
San Antonio, TX
