[GRASSLIST:5708] Re: Creating DTM from shapefiles
Māris Nartišs
maris.nartiss at gmail.com
Thu Feb 10 07:05:47 EST 2005
Seems, that joining two vector data sets (shapefiles) in Grass is
"mission impossible".
> What happens if you append 2 files with attribute tables that have different
> formats?
Actualy for me, lamer, they look like same:
v.db.connect map=augstump driver=dbf
database=/home/maris/Test_in_grass/testlocation/testmapset/dbf/
key=cat layer=1 -c
INTEGER|CAT
DOUBLE PRECISION|AUGST
v.db.connect map=izol_p driver=dbf
key=cat layer=1 -c
INTEGER|CAT
And v.append error:
v.append vect1=augstump vect2=izol_p vmerged=augstump_izol_p
vtype=point vlayer=1
Exporting 74 points/lines...
74 features written
Exporting 172640 points/lines...
172640 features written
Datum 'unknown' not recognised by GRASS and no parameters found. Datum
transformation will not be possible using this projection information.
Over-riding projection check.
Proceeding with import...
Layer: augstump_izol_p
DBMI-DBF driver error:
Column 'CAT' already exists (duplicate name)
Cannot create table.
Error in db_execute_immediate()
Cannot create table: create table augstump_izol_p (cat integer, CAT
integer, AUGST double precision)
_______________________________________
I know what I want, but duno how to get it.
My idea: 2 vect. data sets with 2 dbs. Take first of them, get max cat
num. Take second one and increase cat by first max cat num. Append
second to first w/o problems (ie. cat 2 >> 1), cuz cat nums not
owerlap. Wola. One data set containing data from both input sets.
Is it possible in Grass? Or I need to start to study ArcInfo?
Oh, yeah. That datum thing. As v.append has problems with db, i dont
think, that setting other datum will help.
Anyway, heres msg. from v.in.ogr:
"GRASS_INFO_WARNING(2915,1): Datum 'GRS_1980' not recognised by GRASS
and no parameters found. Datum transformation will not
Projection of input dataset and current location appear to match.
Proceeding with import..."
Any ideas, links to docs/tutorials/man pages welcome.
Maris.
On Tue, 08 Feb 2005 00:16:53 -0700, Michael Barton
<michael.barton at asu.edu> wrote:
> M?ris
> Thanks for trying v.append. Your test seems to answer one question I have:
> formats? V.append (ogr2ogr that is) will make a new table with ALL the
> fields of both tables and attempt to fill them from each table as
> appropriate. However, v.append only really makes sense if you have identical
> attribute tables for the two files you are trying to merge. In your case,
> you have fields with different names in each of the two files.
> With respect to the first error, it looks like you don't have a datum
> specified and ogr2ogr wants one. Could you try it with 2 files that DO have
> a datum specified (the SAME datum) and have identical attribute table
> formats (same field names and field formats)?
> Michael
> C. Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> PO Box 872402
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> Phone: 480-965-6262
> Fax: 480-965-7671
> www: <www.public.asu.edu/~cmbarton>
