[GRASSLIST:5715] RE: r.in.gdal - tiff import problem
Patton, Eric
epatton at nrcan.gc.ca
Thu Feb 10 11:21:31 EST 2005
I ran into the same problem you mentioned while trying to import geotiffs
into Grass 6.0 Cygwin. I'm not sure if a fix has been made for the r.in.gdal
problem, but the short-term workaround I used was to load my tiff into a
graphics program like the GIMP, resave the tiff thereby erasing all
georeferencing info in the header, create a worldfile, then import the tiff
into Grass 5.4 using r.in.tiff (which is not dependent on GDAL libraries).
~ Eric.
Eric Patton
Technologist, Geo-Spatial Data Services
Geological Survey of Canada (Atlantic)
Natural Resources Canada
Bedford Institute of Oceanography
Dartmouth, Nova Scotia, Canada B2Y 4A2
Postal address: P.O. Box 1006
Courier address: 1 Challenger Drive
Telephone: (902)426-7732
Facsimile: (902)426-4104
E-mail: epatton at NRCan.gc.ca
-----Original Message-----
From: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu] On
Behalf Of Pedro Camilo Alcántara Concepción
Sent: Thursday, February 10, 2005 10:13 AM
To: grasslist
Subject: [GRASSLIST:5714] r.in.gdal - tiff import problem
Hi list
Recently I installed Cygwin with the whole set of programs in a Windows XP
os, then I installed the precompiled grass 6.0 cvs from the web page
referred on the main grass web site. I follow all the instrucctions.
I just tried to import a Landsat ETM + band already registered by ENVI.
I got the next error:
GRASS 6.0.cvs:~/importar/1946 > r.in.gdal i=ETM1946BZ16REGB1.IMG
o=ETM1946BZ16REGB1
assertion "codecs == NULL" failed: file
"/usr/src/tiff/tiff-3.7.0beta2/libtiff/tif_compress.c", line 258
Aborted (core dumped)
There is a problem between tiff versions?
What can I do?
Best regards
camilo
camilo @ pcbiol.posgrado.unam.mx
camiloalcantara @ hotmail.com
pcbiol.posgrado.unam.mx Thursday Feb 10 2005 08:05:00 CST
Si hubiera previsto las consecuencias me hubiera hecho relojero.
-- Albert Einstein. (1879-1955) Físico alemán.
