[GRASSLIST:5779] Re: 2GB+ in Grass 6.0
    Christian Ferreira
    christian.grass at gmail.com
    Tue Feb 15 08:40:07 EST 2005
 GRASS 6.0 supports reading and writing large files (> 2GB) if it is
possible in your operating system. If you compile with
-D_FILE_OFFSET_BITS=64, you should be able to have raster maps which
are larger than 2Gb.
Did you tried this?
Cheers
Christian
On Mon, 14 Feb 2005 20:38:24 +0100, Maciek Sieczka <werchowyna at pf.pl> wrote:
> Folks
> Is it possible to load a 4.1 GB GeoTiff DEM into Grass 6.0 location? I'm
> getting "file size limit exceeded". Please help!
> Maciek
