[GRASSLIST:5784] AW: AW: Re: v.in.ascii,      grass6.0 binary version for cygwin
    Jan Bartholdy
    mailing_list at jan-bartholdy.de
    Tue Feb 15 10:29:46 EST 2005
Yes, mv works with the test dbf and the dbf from v.in.ascii. I can move both
and they have the -rw-rw-rw- permissions. Can I solve the problem when I
move the *.dbf into the /home/.../topo/dbf/ folder manually with the mv
command?
Jan
> -----Ursprüngliche Nachricht-----
> Von: Moritz Lennert [mailto:mlennert at club.worldonline.be]
> Gesendet: Dienstag, 15. Februar 2005 16:04
> An: Jan Bartholdy
> Betreff: Re: AW: [GRASSLIST:5781] Re: v.in.ascii, grass6.0 binary version
> for cygwin
> On Tue, February 15, 2005 15:44, Jan Bartholdy said:
> > Thanks, Moritz. I had no problems to create the test.dbf with touch
> test.dbf
> > and the permissions are as follow: the /.tmp/Jan1 directory drwxr-xr-x+
> and
> > the test.dbf -rw-rw-rw- and I am the owner of the files...
> try doing the mv command described below... can you do that ? What are the
> permissions and owner settings of the 5164.dbf ?
> Moritz
> >> Von: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu] Im
> >> Auftrag von Moritz Lennert
> >> Gesendet: Dienstag, 15. Februar 2005 14:55
> >> An: Jan Bartholdy
> >> Cc: English Grasslist
> >> Betreff: [GRASSLIST:5781] Re: v.in.ascii, grass6.0 binary version for
> >> cygwin
> >> On Tue, February 15, 2005 14:46, Jan Bartholdy said:
> >> > Dear All,
> >> > I have imported an ASCII table (tab's as field separators) into grass
> >> > without problems using v.in.ascii input= output= without any
> arguments
> >> > (using arguments like columns="...", the problem is the same).
> >> > All coordinates are imported and the correct number of colums and
> their
> >> type
> >> > was recognized. After that, an error message occur: mv: cannot move
> >> > /home../../.tmp/Jan1/5164.dbf to /home/.../topo/dbf/species_1.dbf:
> >> > permission denied.
> >> > After that, the module building topology etc.
> >> > The 5164.dbf file remains in the .temp/Jan1 folder.
> >> > With d.vect, I can display the points, but the labels are not
> present.
> >> > Db.colums gives an error : DBMI-DBF driver error: Table species_1
> >> does'nt
> >> > exist
> >> This looks like you do not have permission to write to the second
> >> directory.
> >> Try to go to the directory and do a "touch test.dbf" or could you do an
> ls
> >> -ld
> >> on the second directory (and its parents) to show the permission
> settings
> >> Moritz
> > ____________
> > Virus checked by G DATA AntiVirusKit
> > Version: AVK 15.0.2975 from 09.02.2005
____________
