[GRASSLIST:5823] Re: Problem installing grass-6.0.0beta2
Wed Feb 16 18:29:41 EST 2005
> I'm trying to install grass-6.0.0beta2 on a Fedora3 system, and the
> configure
> program stops with the error
> checking for location of External PROJ.4 includes...
> checking for proj_api.h... no
> configure: error: *** Unable to locate External PROJ.4 includes.
> The file was not part of the download; however, there is a file
> named "gproj_api.h" in the include subdirectory.  Is this the file I
> need?  Can I simply list the proj_api.h filename to that file?
> Any advice is welcome...
You need to install PROJ.4 first.
it is on the GRASS 6 requirements page:
  http://grass.ibiblio.org/grass60/source/REQUIREMENTS.html
PROJ4 - Projection Library
  http://www.remotesensing.org/proj
Hamish
