[GRASSLIST:5835] v.buffer - my buffer is a mess
    Maciek Sieczka
    werchowyna at pf.pl
    Thu Feb 17 18:00:03 EST 2005
Hi
Please see the attached screenshots. These are supposed to be the 30km
buffers for the 'odra_glogow_brzeg_cl' (blue), a vector line, topologically
clean for sure.
Why are the buffers so awfull? There isn't anything special about my input
data or whatever. Any guess?
The vbuffer.png was made with 'debug=buffer':
v.buffer input=odra_glogow_brzeg_cl output=odra_glogow_brzeg_cl_buf30
type=line layer=1 buffer=30000 tolerance=0.01 debug=buffer
GRASS_INFO_MESSAGE(20920,1): The tolerance in map units: 300
Lines buffers ...
Rebuilding topology ...
Building topology ...
Registering lines:
1 primitives registered
Building areas:
1 areas built
1 isles built
Attaching islands:
Attaching centroids:
Topology was built.
Number of nodes     :   1
Number of primitives:   1
Number of points    :   0
Number of lines     :   0
Number of boundaries:   1
Number of centroids :   0
Number of areas     :   1
Number of isles     :   1
Number of areas without centroid :   1
And vbuffer2.png made with debug=clean:
type=line layer=1 buffer=30000 tolerance=0.01 debug=clean
GRASS_INFO_MESSAGE(21567,1): The tolerance in map units: 300
Lines buffers ...
Building parts of topology ...
Registering lines:
Topology was built.
Number of nodes     :   1
Number of lines     :   0
Number of areas     :   -
Number of isles     :   -
Snapping boundaries ...
Registering points ...
All vertices:   117
Registered points (unique coordinates):   116
Nodes marked as anchor     :   116
Nodes marked to be snapped :     0
Snaps:     0
Snapped vertices :     0
New vertices     :     0
Breaking boundaries ...
Intersections:     0
Intersections:    22
Removing duplicates ...
Duplicates:     0
Duplicates:     1
Duplicates:     2
Duplicates:     3
Duplicates:     4
Attaching islands ...
Building areas:
5 areas built
0 isles built
Attaching islands: Topology was built.
Number of nodes     :   12
Number of primitives:   36
Number of lines     :   0
Number of boundaries:   36
Number of areas     :   5
Number of isles     :   0
Number of incorrect boundaries   :   14
Number of areas without centroid :   5
Registering lines:
24 primitives registered
Building areas:
5 areas built
0 isles built
Attaching islands: Attaching centroids:
Topology was built.
Number of nodes     :   16
Number of primitives:   24
Number of lines     :   0
Number of boundaries:   19
Number of centroids :   5
Number of areas     :   5
Number of isles     :   0
Maciek
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20050218/b241833e/vbuffer2.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20050218/b241833e/vbuffer1.png
