[GRASSLIST:5930] Re: Mosaicking images with mapcalc
Mon Feb 28 05:59:20 EST 2005
Jose Luis Gomez-Dans wrote:
> Working out the average over the whole overlapping region is not hard
> (r.mapcalc 'rast3=0.5*(rast1+rast2)' does it nicely), but how can I
> restrict the overlap region? Do I have to use a mask? is there some
> other way?
It isn't clear what you are trying to achieve.
> Secondly, I have a large number of tiles I want to mosaic (7x7). What's
> the best way to patch them? Can I just average as I outlined above
> (i.e., complete_rast=0.5*(rast11+rast12+rast13...rast77)?
Simply computing the mean of 49 maps in one go would probably produce
an all-null map; the only non-null cells would be those where all 49
corresponding input cells were non-null.
I suspect that you need a weighted sum, e.g.:
	complete_rast = eval(\
	k11 = isnull(rast11),\
	k12 = isnull(rast12),\
	k77 = isnull(rast77),\
	k = k11 + k12 + ... + k77,\
	(if(k11,rast11) + if(k12,rast12) + ... + if(k77,rast77)) / k)
However, if each map only overlaps its immediate neighbours, it may be
more efficient to generate a grid of non-overlapping tiles where each
tile would only need data from at most 4 tiles, then patch the
resulting tiles together with r.patch.
