[GRASSLIST:5261] Re: scripting v.in.ogr
Moritz Lennert
mlennert at club.worldonline.be
Thu Jan 6 04:02:11 EST 2005
On Wed, January 5, 2005 22:23, Sandro Klippel said:
> Dear Kirk
> Im not sure that I understand, but I suggest
> for MAP in `ls ~/projects/wrf/shape_files/*.shp`;
> do v.in.ogr -o dsn=$MAP output=`basename $MAP .shp`
> layer=`basename $MAP .shp`; done
This should probably be:
do v.in.ogr -o dsn=~/projects/wrf/shape_files/ output=`basename $MAP .shp`
as for shapefile, dsn is the directory containing them, not the files themselves.
Moritz
> Em Qua 05 Jan 2005 18:11, Kirk R. Wythers escreveu:
>> I would like to automate a process where shape files are read into
>> GRASS via v.in.ogr. Currently I can issue individual commands like:
>> v.in.ogr -o dsn=~/projects/wrf/shape_files/ output=polys_t59_v1
>> layer=polys_t59_v1
>> where polys_t59_v1 is one of 30 or so different shape files that I want
>> to keep as individual vectors. What I need is to replace polys_t59_v1
>> with a variable that would hold each shape file temporarily while it is
>> read into GRASS.
>> Can anyone get me started with this kind of script. In the past I've
>> used:
>> for MAP in `g.mlist` ; do
>> to hold map names that are listed, but this will not work because the
>> shape files are not in GRASS yet.
>> Thanks,
>> Kirk R. Wythers
>> Dept. of Forest Resources
>> University of Minnesota
>> email: kwythers at umn.edu
>> tel: 612.625.2261
>> fax: 612.625.5212
> Instituto IGARÉ
> http://geocities.yahoo.com.br/institutoigare
> e-mail: institutoigare at yahoo.com.br
