[GRASSLIST:5286] Re: v.out.ascii Segfault -- backup plan?
Jachym Cepicky
jachym.cepicky at centrum.cz
Tue Jan 11 02:44:29 EST 2005
Hi!
On Mon, Jan 10, 2005 at 05:38:08PM -0800, Dylan Beaudette wrote:
> Just posted a bug report for v.out.ascii:
> Same bug as #2851 posted 3 weeks ago, but on PPC.
> Example Code:
> v.out.ascii input=trails_57 output=trails.xy
> Segmentation fault
> Compile Time Arguments:
> ./configure --with-tcltk-includes=/usr/include/tcl8.3 --without-postgres
> --without-odbc --with-mysql --with-mysql-includes=/usr/include/mysql/
> --with-blas --with-lapack --with-freetype
> --with-freetype-includes=/usr/include/freetype2
> System is Debian/testing
> Any ideas to workarounds until this is working again? I have considered
> exporting lines as SHP file, and then dumping the xy coords with ogrinfo
> -al ... any ideas for a better solution?
> thanks in advance!
I thought, I'm the only one, who gets this bug! I have two installations of
Sarge + GRASS 5.7 and both of them are segfaulting by v.out.ascii.
Here some details:
I use debian gnu linux sarge. Before I started, I run rm -rf on
/usr/local/grass-5.7.cvs/ /usr/src/grass57 ~/.grassrc6 and I improved my
/etc/ld.so.conf like this:
/usr/X11R6/lib
/usr/local/lib
/usr/lib/atlas
/usr/local/grass-5.7.cvs/lib
/usr/lib
and run ldconfig
cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 15
model : 2
model name : Intel(R) Celeron(R) CPU 2.00GHz
stepping : 9
cpu MHz : 2019.960
cache size : 128 KB
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 2
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca =
cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe cid
bogomips : 4005.88
cat /proc/meminfo
MemTotal: 1557528 kB
MemFree: 1260100 kB
Buffers: 29436 kB
Cached: 169520 kB
SwapCached: 0 kB
Active: 176884 kB
Inactive: 89052 kB
HighTotal: 655296 kB
HighFree: 410112 kB
LowTotal: 902232 kB
LowFree: 849988 kB
SwapTotal: 1518100 kB
SwapFree: 1518100 kB
Dirty: 260 kB
Writeback: 0 kB
Mapped: 107152 kB
Slab: 14104 kB
Committed_AS: 157320 kB
PageTables: 980 kB
VmallocTotal: 114680 kB
VmallocUsed: 26028 kB
VmallocChunk: 84028 kB
I configured GRASS like this:
CFLAGS=3D"-g -Wall" ./configure --with-cxx --with-postgres-includes=3D/us=
r/include/postgresql/ --with-gdal=3D/usr/bin/gdal-config --with-proj --with=
-motif --with-glw --with-nls --with-freetype --with-freetype-includes=3D/us=
r/include/freetype2/ --with-tcltk-includes=3D/usr/include/tcl8.3/
And I got:
GRASS is now configured for: i686-pc-linux-gnu
Source directory: /usr/src/grass/grass51
Build directory: /usr/src/grass/grass51
Installation directory: /usr/local/grass-5.7.cvs
Startup script in directory: ${exec_prefix}/bin
C compiler: gcc -g -Wall=20
C++ compiler: c++ -g -O2
FORTRAN compiler: =20
Building shared libraries: yes
NVIZ: yes
X11 support: yes
JPEG support: yes
TIFF support: yes
PNG support: yes
Tcl/Tk support: yes
PostgreSQL support: yes
MySQL support: no
OpenGL(R) support: yes
ODBC support: no
FFTW support: yes
BLAS support: no
LAPACK support: no
Motif support: yes
FreeType support: yes
GLw support: yes
NLS support: yes
Readline support: no
C++ support: yes
openDWG support: no
GDAL support: yes
OGR support: yes
then I run make and error.log says:
GRASS GIS compilation log
Started compilation: P=E1 led 7 18:42:50 CET 2005
Errors in:
Finished compilation: P=E1 led 7 19:20:59 CET 2005
In GRASS:
GRASS 5.7.cvs:~ > echo "-592854.20115798|-1149140.62500086"| v.in.ascii out=tmp
Maximum input row length: 35
Maximum number of columns: 2
Minimum number of columns: 2
Building topology ...
1 primitives registered =20
Building areas: 100%
0 areas built =20
0 isles built
Attaching islands: Attaching centroids: 100%
Topology was built.
Number of nodes : 1
Number of primitives: 1
Number of points : 1
Number of lines : 0
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
GRASS 5.7.cvs:~ > v.out.ascii tmp
Segmentation fault
GRASS 5.7.cvs:~ >
NVIZ is running well now.=20
I tryed the memtest86, it looked good.
The complete strace output from "v.out.ascii tmp" can you find on
www.fle.czu.cz/~jachym/tmp/strace.txt
My fried has debian sid apparently with out problem.
Jáchym
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://www.fle.czu.cz/~jachym/gnupg_public_key/
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20050111/43162c73/attachment.bin
