[GRASSLIST:5312] Re: grass and geology
Markus Neteler
neteler at itc.it
Wed Jan 12 03:29:48 EST 2005
On Wed, Jan 12, 2005 at 12:17:03PM -1200, Joel Peter William Pitt wrote:
> Vincent Godard wrote:
> >I am getting the following error message:
> >DBMI-DBF driver error:
> >Column 'GLG' already exists (duplicate name)
> >Cannot create table.
> If you have access to ArcGIS then try opening the file there
> and renaming the second GLG column to something different
> (i.e. GLG2).
You can also use OpenOffice for this:
View -> Data
* Sources -> select your data source (probably "Data source 1")
* Tables
* your table 'whatever_name'
* click right mouse button on table
-> Edit table
-> modify column(s)
-> Save the table.
* 'Exit' from OpenOffice.
Or you can probably also use db.execute, add a new column,
copy over the values from the other column, then remove this column (untested).
Markus
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
