[GRASSLIST:5371] Re: ps.map and database selections
Sat Jan 15 02:47:11 EST 2005
> I need to print out some vector layers but the maps in question are
> printed on the screen as a result of a d.vect.pg command.  I do not
> see anywhere in the ps.map documentation where it says anything about
> database support.
> How do I go about printing these layers?
You will have to use GRASS 5.7 to do this. You can use the "where"
keyword in ps.map's vector drawing commands to limit via SQL query.
Hamish
