[GRASSLIST:5373] Re: Compilation errors on grass6.0
samuel cavalcante
rioapaporis at yahoo.com.br
Sat Jan 15 06:49:31 EST 2005
hi,
i tried to compile grass6 beta1 but there were errros
in so many modules...
after the log message i changed into mentioned
directories (some of them) but it didn't work as
well...
i'm using debian based XandrOS
CFLAGS="-g -Wall" ./configure
--with-tcltk-includes=/usr/include/tcl8.3
=/usr/include/tk8.3 --without-postgres --without-odbc
GRASS GIS compilation log
Started compilation: Dom Jan 16 07:34:22 BRST 2005
Errors in:
/home/samuel/grass-6.0.0beta1/lib/vector/diglib
/home/samuel/grass-6.0.0beta1/lib/vector/Vlib
/home/samuel/grass-6.0.0beta1/lib/sites
/home/samuel/grass-6.0.0beta1/lib/rst/interp_float
/home/samuel/grass-6.0.0beta1/lib/ogsf
/home/samuel/grass-6.0.0beta1/db/drivers/ogr
/home/samuel/grass-6.0.0beta1/display/d.extend
/home/samuel/grass-6.0.0beta1/display/d.path
/home/samuel/grass-6.0.0beta1/display/d.vect
/home/samuel/grass-6.0.0beta1/display/d.vect.chart
/home/samuel/grass-6.0.0beta1/display/d.what.vect
/home/samuel/grass-6.0.0beta1/display/d.zoom
/home/samuel/grass-6.0.0beta1/general/g.proj
/home/samuel/grass-6.0.0beta1/general/g.region/cmd
/home/samuel/grass-6.0.0beta1/general/manage/lib
/home/samuel/grass-6.0.0beta1/general/manage/cmd
/home/samuel/grass-6.0.0beta1/imagery/i.vpoints
/home/samuel/grass-6.0.0beta1/ps/ps.map
/home/samuel/grass-6.0.0beta1/raster/r.contour
/home/samuel/grass-6.0.0beta1/raster/r.cost
/home/samuel/grass-6.0.0beta1/raster/r.flow
/home/samuel/grass-6.0.0beta1/raster/r.le/r.le.setup
/home/samuel/grass-6.0.0beta1/raster/r.random
/home/samuel/grass-6.0.0beta1/raster/r.region
/home/samuel/grass-6.0.0beta1/raster/r.resamp.rst
/home/samuel/grass-6.0.0beta1/raster/r.to.vect
/home/samuel/grass-6.0.0beta1/raster/r.in.gdal
/home/samuel/grass-6.0.0beta1/vector/v.buffer
/home/samuel/grass-6.0.0beta1/vector/v.build
/home/samuel/grass-6.0.0beta1/vector/v.build.polylines
/home/samuel/grass-6.0.0beta1/vector/v.category
/home/samuel/grass-6.0.0beta1/vector/v.clean
/home/samuel/grass-6.0.0beta1/vector/v.convert
/home/samuel/grass-6.0.0beta1/vector/v.db.connect
/home/samuel/grass-6.0.0beta1/vector/v.db.select
/home/samuel/grass-6.0.0beta1/vector/v.digit
/home/samuel/grass-6.0.0beta1/vector/v.distance
/home/samuel/grass-6.0.0beta1/vector/v.extract
/home/samuel/grass-6.0.0beta1/vector/v.hull
/home/samuel/grass-6.0.0beta1/vector/v.info
/home/samuel/grass-6.0.0beta1/vector/v.in.ascii
/home/samuel/grass-6.0.0beta1/vector/v.in.db
/home/samuel/grass-6.0.0beta1/vector/v.in.region
/home/samuel/grass-6.0.0beta1/vector/v.in.sites
/home/samuel/grass-6.0.0beta1/vector/v.kcv
/home/samuel/grass-6.0.0beta1/vector/v.kernel
/home/samuel/grass-6.0.0beta1/vector/v.label
/home/samuel/grass-6.0.0beta1/vector/v.proj
/home/samuel/grass-6.0.0beta1/vector/v.mkgrid
/home/samuel/grass-6.0.0beta1/vector/v.neighbors
/home/samuel/grass-6.0.0beta1/vector/v.net
/home/samuel/grass-6.0.0beta1/vector/v.net.alloc
/home/samuel/grass-6.0.0beta1/vector/v.net.iso
/home/samuel/grass-6.0.0beta1/vector/v.net.path
/home/samuel/grass-6.0.0beta1/vector/v.net.salesman
/home/samuel/grass-6.0.0beta1/vector/v.net.steiner
/home/samuel/grass-6.0.0beta1/vector/v.normal
/home/samuel/grass-6.0.0beta1/vector/v.out.ascii
/home/samuel/grass-6.0.0beta1/vector/v.out.dxf
/home/samuel/grass-6.0.0beta1/vector/v.out.pov
/home/samuel/grass-6.0.0beta1/vector/v.overlay
/home/samuel/grass-6.0.0beta1/vector/v.patch
/home/samuel/grass-6.0.0beta1/vector/v.perturb
/home/samuel/grass-6.0.0beta1/vector/v.qcount
/home/samuel/grass-6.0.0beta1/vector/v.random
/home/samuel/grass-6.0.0beta1/vector/v.reclass
/home/samuel/grass-6.0.0beta1/vector/v.sample
/home/samuel/grass-6.0.0beta1/vector/v.segment
/home/samuel/grass-6.0.0beta1/vector/v.select
/home/samuel/grass-6.0.0beta1/vector/v.surf.idw
/home/samuel/grass-6.0.0beta1/vector/v.surf.rst
/home/samuel/grass-6.0.0beta1/vector/v.transform
/home/samuel/grass-6.0.0beta1/vector/v.to.db
/home/samuel/grass-6.0.0beta1/vector/v.to.points
/home/samuel/grass-6.0.0beta1/vector/v.to.rast
/home/samuel/grass-6.0.0beta1/vector/v.type
/home/samuel/grass-6.0.0beta1/vector/v.univar
/home/samuel/grass-6.0.0beta1/vector/v.voronoi
/home/samuel/grass-6.0.0beta1/vector/v.what.rast
/home/samuel/grass-6.0.0beta1/vector/v.vol.rst
/home/samuel/grass-6.0.0beta1/vector/v.out.ogr
/home/samuel/grass-6.0.0beta1/vector/v.in.ogr
/home/samuel/grass-6.0.0beta1/vector/v.external
/home/samuel/grass-6.0.0beta1/visualization/nviz
Finished compilation: Dom Jan 16 07:36:03 BRST 2005
(In case of errors please change into the directory
with error and run 'make')
changed into /visualization/nviz
run make
error message:
cd src ; make
make[1]: Entering directory
`/home/samuel/grass-6.0.0beta1/visualization/nviz/src'
gcc -I/home/samuel/grass-6.0.0beta1/include
-I/home/samuel/grass-6.0.0beta1/dist./include/grass
-g -Wall -Wall -Wconversion -Wno-implicit-int
-I/usr/X11R6/include -I/usr/include/tcl8.3
-D_NO_PROTO -D__STDC__ -I/usr/include
-DPACKAGE=\""grassmods"\"
-I/home/samuel/grass-6.0.0beta1/dist./include/grass \
-o OBJ./nvizAppInit.o -c nvizAppInit.c
<command line>:5:1: warning: "__STDC__" redefined
In file included from nvizAppInit.c:9:
interface.h:22:19: gsurf.h: No such file or directory
interface.h:23:21: gstypes.h: No such file or
directory
interface.h:86: error: `MAX_CPLANES' undeclared here
(not in a function)
interface.h:87: error: `MAX_CPLANES' undeclared here
(not in a function)
interface.h:88: error: `MAX_CPLANES' undeclared here
(not in a function)
interface.h:90: error: `MAX_LIGHTS' undeclared here
(not in a function)
nvizAppInit.c:43: warning: `RunScripts' defined but
not used
make[1]: *** [OBJ./nvizAppInit.o] Error 1
make[1]: Leaving directory
make: *** [nvwish] Error 2
_______________________________________________________
Yahoo! Acesso Grátis - Instale o discador do Yahoo! agora. http://br.acesso.yahoo.com/ - Internet rápida e grátis
