[GRASSLIST:5387] patching 2 colored maps
ivan marchesini
marchesini at unipg.it
Mon Jan 17 07:03:44 EST 2005
Dear users...
I've got this problem:
I have two 8 bit colored maps that I have to patch together...
so I use :
v.patch input=map1,map2 output=map3
the problem is that in the resultant map3 only the first map is correcly
patched... the other one soffers of some kind of alteration of the
transparency and of the colours... so the patched map is unuseful!!!!
did you have some similar problem?? how do you solve it???
thank you....
ivan
ivan marchesini <marchesini at unipg.it>
