[GRASSLIST:5420] Re: Difference between using precompiled binaries
and compiling source code!
Moritz Lennert
mlennert at club.worldonline.be
Tue Jan 18 08:01:58 EST 2005
On Tue, January 18, 2005 13:02, Michaela Kinberger said:
> dear list,
> i´m using grass54 binaries. what´s the difference between using
> precompiled binaries and compiling source code! (for all grass versions).
If you want to be able to modify some module or just recompile one particular
module after someone has posted a bugfix for it, then you should compile from
source code as you can then selectively update the parts you want.
If you don't think you need/want to do that, the precompiled binaries are
definitely easier to install.
Moritz
