[GRASSLIST:5456] Re: problems with r.in.srtm
Markus Neteler
neteler at itc.it
Thu Jan 20 09:26:12 EST 2005
On Wed, Jan 19, 2005 at 02:28:26PM -0600, William K wrote:
> First, r.in.srtm is meant to run on zip file as downloaded. It
> automatically unzips it, creates the support files and imports it. It
> figures out the extents of the srtm tile from the file name, so you
> can't rename it. It goes thru an intermediate geotif, so if it worked
> it should have left behind a tiff as well. It probably stopped because
> it coouldn't find the zip. The .bil file should be OK to import with
> r.in.gdal.
> But there is a bug in the code that figures out the extents so maybe
> that's why it's not registering with your data. I gave a patch to
> Markus a while back but he hasn't applied it to the CVS yet, I'll have
> to bother him about that again.
Since yesterday evening the patch is in CVS (will appear also in 6.0.0beta2).
Markus
