[GRASSLIST:5497] Re: v.in.ascii
Francesco Mirabella
mirabell at unipg.it
Mon Jan 24 04:38:21 EST 2005
Hi Hamish,
many thanks for yout reply, yes, the "pipe" option works, so as you
said, maybe is the "fs=tab" part which is having problems.....
However there still is a problem with the table. I am on postgres:
I run <db.connect>, <db.login> and <v.db.connect>, the connection seems to work, but:
even if in the query of the vector points (<d.what.vect>) the info in the form are well displayed and the name of the table exist, there is a messege like:
..."Cannot open database 'host=localhost,dbname=cesco_pgsql,user=mirabell' by driver 'pg" ..... which does not seem true because the info in the form, including the table name, are correct.
Moreover, even if the table seems created (according the d.what.vect form), if I access the database with e.g. pgaccess the table does not exist... so, where is it putting the table??
any ideas? am I wrong somewhere??
Many thanks for your support
cheers
Francesco
On Mon, Jan 24, 2005 at 12:18:34PM +1300, Hamish wrote:
> > I am on grass60beta1:
> > I need to import an ascii tab-separated file composed of 4 columns:
> > cat,lat,long,depth
> > I have a problem with v.in.ascii, I get "get xcol> minimum last column
> > number "
> > This is what I do and get:
> > GRASS 6.0.cvs:~ > v.in.ascii -z input=LatLon_AC_thous.dat
> > output=prova_again1 fs=tab columns='x double, y double, z double,
> > cat int' x=2 y=3 z=4 cat=1
> > D2/3: Vect_open_new(): name = prova_sismi_again1
> > D1/3: Vect_set_thresh(): thresh = 0.000000
> > D1/3: V1_open_new_nat(): name = prova_sismi_again1
> > D1/3: Vect_get_thresh(): thresh = 0.000000
> > D1/3: dig__write_head()
> > D1/3: write coor size (0) to head
> > D2/3: coor body offset 14
> > D3/3: dig_init_plus()
> > D1/3: dig_spidx_init()
> > D3/3: dig_cidx_init()
> > D3/3: Vect_hist_command()
> > D3/3: G_recreate_command()
> > Maximum input row length: 26
> > Maximum number of columns: 1
> > Minimum number of columns: 1
> ^^^^ It could only see one column.
> > ERROR: xcol > minimum last column number
> as it only thinks there is one column, column 2 (ie x) doesn't exist.
> > GRASS 6.0.cvs:~ >
> > Apparently x=2 is wrong (?) but if I delete the column of <cat> and
> > try to import with <x=1, y=2, z=3> I get the same ERROR with ycol
> > (i.e. ERROR: ycol > minimum last column number
> > Can anyone tell me where I am wrong??
> It'll be the fs=tab part which is having problems. try fs='\t'?
> Still working on fixing this up; haven't finshed yet; you might try
> updating from CVS although that is still in flux I think.
> try doing a search & replace of the tabs with "|" in the mean time?
> Hamish
