[GRASSLIST:5504] Re: suse 9.1 - rpm on suse 9.2
Jason Joines
jason at joines.org
Mon Jan 24 11:57:33 EST 2005
Helmut Kudrnovsky wrote:
> hi grass-friends,
> suse 9.2 is running on my computer. is it possible to run the grass6.0beta suse 9.1 - rpm on this machine? i saw that gdal 1.2.5 asks for libjasper 1.700, but on suse 9.2 there is version 1.701. and this could be a problem.
> greetings from tyrol
> helli
> __________________________________________________________
> Mit WEB.DE FreePhone mit hoechster Qualitaet ab 0 Ct./Min.
> weltweit telefonieren! http://freephone.web.de/?mc=021201
If that's the only dependency problem you have when installing gdal,
just add the "--nodeps" option to your rpm command and it'll work fine
with the newer libjasper.
Jason Joines
