[GRASSLIST:5540] Re: v.mkgrid extract grid sections
Radim Blazek
blazek at itc.it
Thu Jan 27 03:14:43 EST 2005
Use v.extract type=area
Radim
Dylan Beaudette wrote:
> On Wednesday 26 January 2005 06:09 pm, Hamish wrote:
>>>I have used v.mkgrid (GRASS6-CVS) in the past to make vector grids,
>>>and all has been well.
>>>However, this morning I tried to extract a single square from the
>>>output from v.mkgrid, and was only able to get either a single
>>>centroid (almost correct), or the entire boundary (not good). Since
>>>the boundaries do not have CATs, there is no way for me to extract a
>>>single boundary...
>>>Any ideas?
>>what about
>> v.category type=boundary option=add
>>to add category numbers to the boundaries?
> Thanks! ... this gives the boundaries CATs... but for some reason, each grid
> square is made up of about 8 line segments (3 for top and bottom lines, 1 for
> each vertical line)...
> My hope is that i can make each grid "cell" into a discreet polygon, that can
> be used to set the region -- i.e. so that i can accurately subsample a larger
> map.
> thanks!
