[GRASSLIST:5544] Re: v.digit - editing attributes
Robert S. Nuske
rnuske at gwdg.de
Thu Jan 27 12:31:13 EST 2005
> > I also can not display the attributes of points or centroids.
> Do you mean that d.what.vect in GUI mode doesn't work? That would
would be
> exactly what I'm struggling with. See a bug report:
> http://intevation.de/rt/webrt?serial_num=2927 and let us know if you have
> the same problem.
No, I meant displaying attributes within v.digit.
But, I had the problem you described above using d.what.vect and got
around it by using the '-x' switch, so far.
Anyhow, the patch you mentioned works for v.digit and d.what.vect, as well.
Thanks for the pointer.
cheers,
robert
