[GRASSLIST:7441] Re: error message in configuration
Glynn Clements
glynn at gclements.plus.com
Mon Jul 4 11:06:33 EDT 2005
orkun wrote:
> checking for tiffio.h... no
> configure: error: *** Unable to locate TIFF includes.
> what does (debian) package have tiffio.h ?
Searching for tiffio.h using the search tool at:
http://www.us.debian.org/distrib/packages#search_contents
suggests that the relevant package is:
libdevel/libtiff4-dev
A list of generic packages which GRASS requires can be found in the
REQUIREMENTS.html file. Packages for specific OS distributions tend to
use similar names. However, many distributions split packages into
"user" and "developer" packages (e.g. libtiff4 and libtiff4-dev). You
need both packages in order to compile GRASS, but only the user
package to run it.
