[GRASSLIST:7468] Re: r.terraflow failured
Māris Nartišs maris.nartiss at gmail.com
Wed Jul 6 04:09:10 EDT 2005
is this large file support detected during configure and then enabled,
if OS supports it? Lots of endusers do not understand that -D blablah
thing.
wbr,
Maris.
On 7/5/05, Andrew Danner <adanner at cs.duke.edu> wrote:
> A couple of things:
>  1) creating and accessing files larger than 2GB requires large file
> support under Linux. Typically you can do this by including the compile
> flags -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE when compiling
> r.terraflow. If you do not see these flags when compiling, it will not
> be able to read/write files bigger than 2GB (a 32-bit file offset)
