[GRASSLIST:7496] Re: import HDF files
Ian MacMillan
ian_macmillan at umail.ucsb.edu
Thu Jul 7 14:27:54 EDT 2005
Unfortunately I ran into this problem a few months ago with MASTER
data. I never found a solution :(, but there is some stuff in the mail
archives that deal with this same issue.
G'luck
-Ian
On Jul 6, 2005, at 6:37 PM, Michael Barton wrote:
> Carlos,
> It seems like you are correct. Somehow there is no coordinate system
> specified in the HDF file. This is strange. I'm copying the
> developer's list
> in case someone else has run into this.
> Michael
> On 7/6/05 1:04 PM, "Carlos Guâno Grohmann" <carlos.grohmann at gmail.com>
> wrote:
>> I tried r.in.aster:
>> r.in.aster
>> input=/home/guano/grassdata/
>> AST.L1B.00309052003132740.09242003132138.hdf
>> proctype=L1B band=1 output=teste
>> georeferencing aster image
>> gdalwarp -t_srs +proj=lcc +lat_0=-18.0000000000 +lat_1=-8.0000000000
>> +lat_2=-28.0000000000 +lon_0=-46.0000000000 +x_0=2000000000.0000000000
>> +y_0=5000000000.0000000000 +a=6378160 +rf=298.25 +no_defs
>> +towgs84=-60.0,-2.0,-41.0
>> HDF4_SDS:ASTER_L1B:"/home/guano/grassdata/
>> 2138.hdf":2
>> /home/guano/grassdata/amsul_lambert/sad69/.tmp/valhalla/27109.0.tif
>> A target coordinate system was specified, but there is no source
>> coordinate
>> system. Consider using -s_srs option to provide a source coordinate
>> system.
>> Operation terminated.
>> importing into GRASS
>> ERROR 4:
>> `/home/guano/grassdata/amsul_lambert/sad69/.tmp/valhalla/27109.0.tif'
>> does not exist in the file system,
>> and is not recognised as a supported dataset name.
>> Something is worong with the coordinate system, which is not set in
>> the image.
>> This is the first lines of gdalinfo:
>> Driver: HDF4/Hierarchical Data Format Release 4
>> Size is 512, 512
>> Coordinate System is `'
>> Metadata:
>> HDFEOSVersion=HDFEOS_V2.6
>> IDOFASTERGDSDATAGRANULE=ASTL1B 0309051327400309240184
>> tks Carlos
> ____________________
> C. Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> PO Box 872402
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> Phone: 480-965-6262
> Fax: 480-965-7671
> www: <www.public.asu.edu/~cmbarton>
