[GRASSLIST:7527] Re: First reactions
Markus Neteler
neteler at itc.it
Wed Jul 13 03:42:29 EDT 2005
On Tue, Jul 12, 2005 at 02:30:21PM +0200, Martin Wegmann wrote:
> On Friday 08 July 2005 10:09, Hamish wrote:
> > But GRASS does require a UNIX environment to run in, so it has to use
> > something like Cygwin to provide that, along with all the complexity
> > that entails.
> I did not know that. GRASS requires a UNIX environment and hence will never be
> available as "*.exe"? Well, then does the Windows user world have to deal
> with Cygwin.
Work is ongoing at University of Trento to port GRASS to MS-Windows
as generic EXE/DLLs using MingW compiler. Most of the libraries are
done, module testing is ongoing. Once working, Cygwin will be no longer
needed (although maybe helpful for scripting etc).
Markus
