[GRASSLIST:7555] Re: vectorisation - vertex limit?
Martin Rutzinger
Martin.Rutzinger at uibk.ac.at
Fri Jul 15 05:53:22 EDT 2005
Hi Markus!
You are right - there is no limit of vector primitives. It's a problem of the
thinning. The raster I used is not thinned properly.
Output of r.to.vect:
update_list: crowded cell 7H (11,10)
ERROR: cell file is not thinned properly.
Please run r.thin
So the vectorisation stops at a "crowded cell". Unfortunately it is not
possible to remove this crowded cells with running r.thin again:
File obj_raster1 -- 21 rows X 26 columns
Bounding box: l = 2, r = 27, t = 2, b = 22
Path number 1
Deleted 0 pixels
thinning completed successfully.
Output file 21 rows X 26 columns
Window 21 rows X 26 columns
Thanks alot
Martin
Zitat von Markus Neteler <neteler at itc.it>:
> Hi Martin,
> > The Problem is the vectorisation with r.to.vect: The resulting vector
> (lines) I
> > get is not "finished" when displaying it (bottom part is missing). Further
> > analysis are not possible with this vector - always getting the error:
> > ERROR: Cannot open old vector mwin_vector1 at schlesi on level 2.
> No, there is no such limit in the vector model. I just tried
> to split the Spearfish roads map into 1m segments:
> GRASS 6.1.cvs (spearfish60): > v.split in=roads out=roads_split length=1
> 100%
> Erzeuge Topologie ...
> 392579 primitives registriert
> Building areas: 100%
> 0 Flächen erstellt
> 0 Inselflächen erstellt
> Füge Inselflächen hinzu:
> Füge Zentroide hinzu: 100%
> Die Topologie wurde erstellt.
> Anzahl von Knoten : 392430
> Anzahl von Primitives : 392579
> Anzahl von Punkten : 0
> Anzahl von Linien : 392579
> Anzahl von Boundaries : 0
> Anzahl von Zentroiden : 0
> Anzahl von Flächen : 0
> Anzahl von Inseln : 0
> No problem (not even slow :-).
> Probably your disk is full and GRASS doesn't report this properly?
> Please post the full ourput of r.to.vect to better understand
> the problem.
> Markus
