[GRASSLIST:7580] Re: Synergy between Grass/Python/GMT
David Finlayson
david.p.finlayson at gmail.com
Mon Jul 18 01:19:55 EDT 2005
Nice web site. You've obviously thought about this for a while now.
Maybe we can work on this together to get it polished up for general
consumption?
David
On 7/17/05, Dylan Beaudette <dylan at iici.no-ip.org> wrote:
> David,
> As I alluded to last message, here is the link to the BASH GRASS--GMT
> framework that I have put together to help with my map making:
> http://169.237.35.250/~dylan/grass_user_group/
> with a sample map :
> http://169.237.35.250/~dylan/grass_user_group/map1.html
> ...however I am looking forward to checking out your python code...
> BASH is a little crufty..
> Dylan Beaudette
> Soils and Biogeochemistry Graduate Group
> University of California at Davis
> 530.754.7341
> On Jul 17, 2005, at 2:17 PM, David Finlayson wrote:
> > I have posted my GRASS -> GMT script on my web site (r.out.gmt.py):
> > http://students.washington.edu/dfinlays/scripts/
> > If anyone finds this useful, please send me suggestions. I will keep
> > working on it until it isn't such a hack.
> > Currently, it converts a raster, its colormap and optionally an
> > intensity raster (such as shaded relief) to GMT format. It then builds
> > a skeleton GMT plotting file that includes the raster (optionally
> > shaded with the intensity grid), a graticule and map decorations with
> > all of the tedious scale calculations already performed.
> > You need to edit the results to get it to look right, but the time
> > savings (for me) is probably close to an hour a plot over doing the
> > same steps manually.
> > David
> > On 7/16/05, Dylan Beaudette <dylan at iici.no-ip.org> wrote:
> >> David,
> >> I am extremely interested in any possible ways to streamline the
> >> GRASS-GMT workflow.
> >> I have started documenting a BASH shell version of the process, but a
> >> python interface might be able to provide a tremendous amount of
> >> flexibility compared to BASH.
> >> The website where this is documented is currently down (power outage
> >> while I was out in the field...), but I will try and have it back up
> >> in
> >> a couple hours. Please let me know about any future plans with this--
> >> Cheers,
> >> Dylan Beaudette
> >> 530.754.7341
> >> On Jul 15, 2005, at 10:39 PM, David Finlayson wrote:
> >>> I'd be happy to share it, but frankly it's pretty crude. I'd be
> >>> embarrassed to foist this off as a good example of either Grass or
> >>> Python (though maybe it is a good example of how flexible this
> >>> combination is, even for light-weight programmers). The class simply
> >>> wraps an interface around a few standard GRASS commands and captures
> >>> the results (r.region for example). My dream is to write a real
> >>> Python
> >>> interface to the Grass programming interface, but that project is on
> >>> hold until I finish my PhD.
> >>> Is there a good place on the wiki for sharing scripts? When I get
> >>> this
> >>> GMT thing polished up I think it will be quite useful for folks who
> >>> use GMT.
> >>> David
> >>> On 7/15/05, Stephan Holl <holl at gdf-hannover.de> wrote:
> >>>> Hello David,
> >>>> On Fri, 15 Jul 2005 16:27:18 -0700 David Finlayson
> >>>> <david.p.finlayson at gmail.com> wrote:
> >>>>> I've been working on a script to convert GRASS rasters directly
> >>>>> into
> >>>>> GMT plots in a single command. So far it converts the raster to GMT
> >>>>> format, copies over the colormap and builds a simple graticule and
> >>>>> scale bar. Works well.
> >>>>> In the process of building this script, however, I discovered there
> >>>>> is
> >>>>> some great synergy possible between IPython (the interactive python
> >>>>> shell) and GRASS. Here is how it works:
> >>>>> 1) Launch ipython from within your grass shell
> >>>>> 2) import a simple class designed to work with rasters
> >>>>> 3) BINGO! you've got full control of command line grass + full
> >>>>> interactive Python abilities.
> >>>>> The class I wrote for grass rasters contains a bunch of instance
> >>>>> variables that hold basic info about the raster (resolution,
> >>>>> bounding
> >>>>> box, etc.) and some methods to ease interaction with Python, like a
> >>>>> get_value(X, Y) method.
> >>>> Would you like to share the python class which you wrote for
> >>>> raster-maps?
> >>>> It would be nice having the class in CVS to make it possible for
> >>>> others
> >>>> too?
> >>>> Thanks for your comment
> >>>> Stephan
> >>>> ::ACHTUNG:: Neue Adresse und Telefonnummer ::ACHTUNG::
> >>>> GDF Hannover - Solutions for spatial data analysis and remote
> >>>> sensing
> >>>> Hannover Office - Mengendamm 16d - D-30177
> >>>> Hannover
> >>>> Internet: www.gdf-hannover.de - Email:
> >>>> Phone : ++49-(0)511.39088507 - Fax:
> >>>> ++49-(0)511.39088508
> >>> David Finlayson
> >>> Marine Geology & Geophysics
> >>> School of Oceanography
> >>> Box 357940
> >>> University of Washington
> >>> Seattle, WA 98195-7940
> >>> USA
> >>> Office: Marine Sciences Building, Room 112
> >>> Phone: (206) 616-9407
> >>> Web: http://students.washington.edu/dfinlays
> > David Finlayson
> > Box 357940
> > USA
David Finlayson
Box 357940
USA
