[GRASSLIST:7614] Re: Synergy between Grass/Python/GMT
David Finlayson
david.p.finlayson at gmail.com
Tue Jul 19 01:07:49 EDT 2005
I am wondering if it makes more sense to break up the program into
separate scripts?
1) Convert the color table from grass to gmt (g.out.colortable format=gmt)
2) Converting the raster (r.out.gmt)
3) Suggest output for -R and -J (maybe keep this in GMT land)
I just don't like the spaghetti code I was writing.
David
On 7/18/05, Dylan Beaudette <debeaudette at ucdavis.edu> wrote:
> David,
> Thanks for the reply. The lack of good hard copy output from GRASS has
> driven me to do some hackish things in order to get GMT to produce my
> maps.... I would be more than happy to collaborate on getting a working
> GRASS-GMT framework (python seems like the best glue language as you
> have demonstrated!) . I am excited about trying your script, as it
> solves the color pallette problem that I had been facing for a while. I
> am also working on a v.out.gmt script to convert GRASS vector data and
> attributes into GMT format. Currently the only way to get GRASS vector
> data into GMT is to convert to shapefile, and then convert the geometry
> to GMT format.
> Cheers!
> Dylan Beaudette
> Soils and Biogeochemistry Graduate Group
> University of California at Davis
> 530.754.7341
> On Jul 17, 2005, at 10:19 PM, David Finlayson wrote:
> > Nice web site. You've obviously thought about this for a while now.
> > Maybe we can work on this together to get it polished up for general
> > consumption?
> > David
> > On 7/17/05, Dylan Beaudette <dylan at iici.no-ip.org> wrote:
> >> David,
> >> As I alluded to last message, here is the link to the BASH GRASS--GMT
> >> framework that I have put together to help with my map making:
> >> http://169.237.35.250/~dylan/grass_user_group/
> >> with a sample map :
> >> http://169.237.35.250/~dylan/grass_user_group/map1.html
> >> ...however I am looking forward to checking out your python code...
> >> BASH is a little crufty..
> >> Dylan Beaudette
> >> 530.754.7341
> >> On Jul 17, 2005, at 2:17 PM, David Finlayson wrote:
> >>> I have posted my GRASS -> GMT script on my web site (r.out.gmt.py):
> >>> http://students.washington.edu/dfinlays/scripts/
> >>> If anyone finds this useful, please send me suggestions. I will keep
> >>> working on it until it isn't such a hack.
> >>> Currently, it converts a raster, its colormap and optionally an
> >>> intensity raster (such as shaded relief) to GMT format. It then
> >>> builds
> >>> a skeleton GMT plotting file that includes the raster (optionally
> >>> shaded with the intensity grid), a graticule and map decorations with
> >>> all of the tedious scale calculations already performed.
> >>> You need to edit the results to get it to look right, but the time
> >>> savings (for me) is probably close to an hour a plot over doing the
> >>> same steps manually.
> >>> David
> >>> On 7/16/05, Dylan Beaudette <dylan at iici.no-ip.org> wrote:
> >>>> David,
> >>>> I am extremely interested in any possible ways to streamline the
> >>>> GRASS-GMT workflow.
> >>>> I have started documenting a BASH shell version of the process, but
> >>>> a
> >>>> python interface might be able to provide a tremendous amount of
> >>>> flexibility compared to BASH.
> >>>> The website where this is documented is currently down (power outage
> >>>> while I was out in the field...), but I will try and have it back up
> >>>> in
> >>>> a couple hours. Please let me know about any future plans with
> >>>> this--
> >>>> Cheers,
> >>>> Dylan Beaudette
> >>>> 530.754.7341
> >>>> On Jul 15, 2005, at 10:39 PM, David Finlayson wrote:
> >>>>> I'd be happy to share it, but frankly it's pretty crude. I'd be
> >>>>> embarrassed to foist this off as a good example of either Grass or
> >>>>> Python (though maybe it is a good example of how flexible this
> >>>>> combination is, even for light-weight programmers). The class
> >>>>> simply
> >>>>> wraps an interface around a few standard GRASS commands and
> >>>>> captures
> >>>>> the results (r.region for example). My dream is to write a real
> >>>>> Python
> >>>>> interface to the Grass programming interface, but that project is
> >>>>> on
> >>>>> hold until I finish my PhD.
> >>>>> Is there a good place on the wiki for sharing scripts? When I get
> >>>>> this
> >>>>> GMT thing polished up I think it will be quite useful for folks who
> >>>>> use GMT.
> >>>>> David
> >>>>> On 7/15/05, Stephan Holl <holl at gdf-hannover.de> wrote:
> >>>>>> Hello David,
> >>>>>> On Fri, 15 Jul 2005 16:27:18 -0700 David Finlayson
> >>>>>> <david.p.finlayson at gmail.com> wrote:
> >>>>>>> I've been working on a script to convert GRASS rasters directly
> >>>>>>> into
> >>>>>>> GMT plots in a single command. So far it converts the raster to
> >>>>>>> GMT
> >>>>>>> format, copies over the colormap and builds a simple graticule
> >>>>>>> and
> >>>>>>> scale bar. Works well.
> >>>>>>> In the process of building this script, however, I discovered
> >>>>>>> there
> >>>>>>> is
> >>>>>>> some great synergy possible between IPython (the interactive
> >>>>>>> python
> >>>>>>> shell) and GRASS. Here is how it works:
> >>>>>>> 1) Launch ipython from within your grass shell
> >>>>>>> 2) import a simple class designed to work with rasters
> >>>>>>> 3) BINGO! you've got full control of command line grass + full
> >>>>>>> interactive Python abilities.
> >>>>>>> The class I wrote for grass rasters contains a bunch of instance
> >>>>>>> variables that hold basic info about the raster (resolution,
> >>>>>>> bounding
> >>>>>>> box, etc.) and some methods to ease interaction with Python,
> >>>>>>> like a
> >>>>>>> get_value(X, Y) method.
> >>>>>> Would you like to share the python class which you wrote for
> >>>>>> raster-maps?
> >>>>>> It would be nice having the class in CVS to make it possible for
> >>>>>> others
> >>>>>> too?
> >>>>>> Thanks for your comment
> >>>>>> Stephan
> >>>>>> ::ACHTUNG:: Neue Adresse und Telefonnummer ::ACHTUNG::
> >>>>>> GDF Hannover - Solutions for spatial data analysis and remote
> >>>>>> sensing
> >>>>>> Hannover Office - Mengendamm 16d - D-30177
> >>>>>> Hannover
> >>>>>> Internet: www.gdf-hannover.de - Email:
> >>>>>> Phone : ++49-(0)511.39088507 - Fax:
> >>>>>> ++49-(0)511.39088508
> >>>>> David Finlayson
> >>>>> Marine Geology & Geophysics
> >>>>> School of Oceanography
> >>>>> Box 357940
> >>>>> University of Washington
> >>>>> Seattle, WA 98195-7940
> >>>>> USA
> >>>>> Office: Marine Sciences Building, Room 112
> >>>>> Phone: (206) 616-9407
> >>>>> Web: http://students.washington.edu/dfinlays
> >>> David Finlayson
> >>> Box 357940
> >>> USA
> > David Finlayson
> > Box 357940
> > USA
David Finlayson
Box 357940
USA
