[GRASSLIST:7654] Re: ERROR: Input map is rotated - cannot import.
    Hamish
    hamish_nospam at yahoo.com
    Wed Jul 20 20:17:44 EDT 2005
> Dear reader, I have received the message above when attempting to
> import  a .tiff using r.in.gdal
> Yet, when I view this tiff in Gimp, it appears to look fine, with
> North up. How do I rectify this?
If you look at the attached meta-data with gdalinfo you will see a
rotation parameter. I think you can use either gdal_translate or
gdalwarp to turn it and keep geocoding, or
"tifftopnm in.tif | pnmtotiff > out.tif" to remove all geocoding.
Someone else will hopefully have a better solution for you.
Hamish
