[GRASSLIST:6982] Re: e00
Markus Neteler
neteler at itc.it
Thu Jun 2 05:02:16 EDT 2005
On Thu, Jun 02, 2005 at 06:53:51AM +0200, Paolo Cavallini wrote:
> Thanks Hamish.
> I was aware that v.in.e00 requires avce00, so I installed Denis Giguere
> packages (I tried to compile, with no success). From the command line,
> avceimport works, but v.in.e00 does not: it complains about
> v.in.e00: 'e00conv' program not found, install it first
> So I guess the package is incomplete?
Yes.
BTW: Daniel Morisette, the author of the package, will publish
a new version soon (with important fixes, e.g. for German CORINE
data).
Markus
> All the best.
> pc
> At 01:49, giovedì 02 giugno 2005, Hamish has probably written:
> > > Is there an howto for converting ArcInfo E00 files in grass? I
> > > installed Denis Giguere packages [1], but grass gives an error
> > > (missing avce00 command). Thanks.
> > > see also:
> > > http://lists.alioth.debian.org/pipermail/pkg-grass-general/2005-February/
> > >000628.html
> > v.in.e00 requires the avce00 library. See the v.in.e00 help page:
> > http://grass.ibiblio.org/grass61/manuals/html61_user/v.in.e00.html
> > http://avce00.maptools.org/
> > Hamish
> Paolo Cavallini
> cavallini at faunalia.it www.faunalia.it www.faunalia.com
> Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
