[GRASSLIST:7076] Re: DXF to Grass dataset
RAVI KUMAR ravivundavalli at yahoo.com
Wed Jun 8 08:32:34 EDT 2005
Hi Hamish,
Text drawn inside a polygon (inscribed text) in a DXF
file
Imported in GRASS should be taken as THE POLYGON'S
ATTRIBUTE
IS THIS POSSIBLE IN GRASS6 NOW?
If, S, may be i need to know some commands prompted.
Thanks in anticipation
Ravi
--- Hamish <hamish_nospam at yahoo.com> wrote:
> > WHY USE AUTOCAD AND WHY NOT DO THE ENTIRE THING IN
> > GRASS??
> why indeed.
> > FOSS software 'Qcad', can be used instead of
> AUTOCAD,
> > and the CAD Draftsmen with limited knowledge can
> make
> > the vector of a geological map after scanning,
> with
> > inscribed text in each geological unit represented
> as
> > a polygon.
> > If GRASS then can import the resultant DXF file
> from
> > Qcad, and make the inscribed text as its
> attribute, it
> > can speedup the process of making digital
> datasets.
> > Hope the GRASS program builders can give a
> solution,
> > like this.
> You can use existing tools for the job. i.e. QGis's
> grass vector
> digitizer or 'v.digit bgcmd=d.rast ..'.
> Hamish
__________________________________
Discover Yahoo!
Use Yahoo! to plan a weekend, have fun online and more. Check it out!
http://discover.yahoo.com/
