[GRASSLIST:7120] Re: Mac OS X binaries and terminal
Konstantinos Theofilis
theofilis at macland.gr
Fri Jun 10 19:08:50 EDT 2005
Well, I managed to do it myself. The main issue was that I needed to
use 'tell application "terminal" set results to do script ' instead
of plain 'do shell script' and also to remove the quoted form of the
path. Also I put the /bin to the path (it wouldnt find mkdir otherwise).
If Lorenzo wants to put the changed script up to his site for
download (some users prefer Terminal.app) I could mail it to him :-)
Kostas Theofilis
On 10 Jun 2005, at 21:03, Konstantinos Theofilis wrote:
> Hi list,
> Is it possible to use Lorenzo's binaries with Terminal.app instead
> of xterm?
> I tried to change the script inside the app (by replacing /.../.../
> xterm with open /Applications/Utilities/Terminal.app) but it
> doesn't work :-(
> (I have the DISPLAY variable set to 0:0 so Terminal works with X11)
> Thanks
> kostas Theofilis
