[GRASSLIST:7230] Re: Compile Errors continue in 6.0.0
Glynn Clements
glynn at gclements.plus.com
Sun Jun 19 00:11:56 EDT 2005
Hamish wrote:
> > > What could be causing this?
> > The above error regarding line 47 of numerical.h. line 47 appears
> > empty, but the jacobi.c section is the closest match,
> Note that in the 6.0.0 source (inferred from the above gcc command) line 47
> read as follows:
> extern struct Command_keys Command_keys[];
Ah, that is a far more likely candidate.
